Excessive Fan noise
KillerbubblesMH
So I have been banging my head against the wall trying to figure out what is causing this excessive fan noise upon boot up with my PC. When powering up it seems the fans go into overdrive even though I can see resources are minimal in task manager for around 5 minutes and than go back to normal
I clean the filter to ensure minimal dust intake as i have three fans, in the front of the PC, in which i use iCUE to monitor the fan speeds and they are hitting around 1600RPM + than goes back down to the 1200RPM mark.
I have checked the fan settings in the BIOS and they are set to quiet setting is applied, just not too sure what else i can check.
Not a deal breaker as the PC has done me wonders for the past 2 years just feels like one day it will go bang.
Don't know where this is the best forum for it but any suggestions would be much appreciated
Is this a PCSpecialist pc? Can you post your full specs from the order page.
KillerbubblesMH
Yeah PCSpecialist PC - Very odd though only past year its started happening and it's not every day but this week has been quite bad.
Specs;
CORSAIR CRYSTAL SERIES 570X RGB GAMING CASE
Intel® Core™ i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
ASUS® TUF Z370-PLUS GAMING II: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE RGB DDR4 3000MHz (2 x 8GB)
8GB NVIDIA GEFORCE GTX 1070 Ti - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
256GB INTEL® 760p M.2 NVMe PCIe SSD (upto 3210MB/sR | 1315MB/sW)
PCS FrostFlow 120 Series High Performance Liquid Cooler
COOLER MASTER MASTERGEL MAKER THERMAL COMPOUND
LED Lighting
50cm RGB LED Strip
WIRELESS 802.11 AC1750 1,300Mbps/5GHz, 450Mbps/2.4GHz PCI-E CARD
The first thing to do is monitor temps with HWMonitor when idle and under load:
Fans respond to temps.
