Exhaust fan not running.
BMC00
Just noticed one of my Corsair case fans (exhaust)is not running? I've tried to see what's going on in the BIOS but it says all 4 fans are running the same.
Would anyone be able to give me some clues as to where to look for a fix? Thanks!!!
B4zookaw
Can you post your specs? Would help us understand how the fan might be connected (e.g. directly to motherboard or to a fan controller).
BMC00
Intel® Core™ i7 12-Core Processor i7-12700F (2.1GHz) 25MB Cache
ASUS® TUF GAMING Z690-PLUS WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x
8GB)
8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP, LHR
500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R,
5000MB/W)
CORSAIR 1000W RMx SERIESTM MODULAR 80 PLUS GOLD,
ULTRA QUIET
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High
Performance CPU Cooler
Extra Case Fans
Microsoft® Edge
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts,
3 Year Labour)
Promotional Item
Get Monster Hunter: Rise & more with select Intel® Core™ Processors
Welcome Book
Logo Branding
PCSpecialist Logo
B4zookaw
And which fan is it? The rear one? Or one connected to the H115 AIO?
Edit: I'm assuming the following fan setup:
  • Two fans connected to AIO radiator installed at the top of the case, with the fans connected to and controlled by the Commander Core that the AIO is connected to.
  • Three LL120 fans installed at the front of the case, connected to either the Commander Core, or a fan repeater that came with case
  • Single non-Corsair fan installed as a rear exhaust, connected directly to a motherboard fan header.
If you can confirm which fan ,we can direct you where to look for a possible loose connection, etc
