Eyefinity spec could use some help :)
AwesomeDude
So I saw quite a Few videos about Eyefinity and I'm thinking of getting a setup with it and need help with a Spec the maximum budget is £1,800 could anyone help?
tom_gr7
Life Serving
i'd look at something like this mate, do you need monitors in that budget? also you will need the eyefinity display adapters, but i dont know which ones you would need as i dont know what outputs are on a 7970. Therefore i'd ask pcs.
CORSAIR CARBIDE SERIES™ 500R WHITE MID TOWER CASE
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX
8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
3GB AMD RADEON™ HD7970 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Memory - 1st Hard Disk
120GB KINGSTON HYPERX SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk
2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
CORSAIR 850W ENTHUSIAST SERIES™ TX850 V2-80 PLUS® BRONZE (£99)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19)
Network Facilities
NO OFFICE SOFTWARE
Quantity
1
Price: £1,543.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-sandy-bridge-pc/
AwesomeDude
Yea, I'm Looking for the Monitors included :p
And the Adapters Looking for 3 monitors Btw Can't stand the Bezels when having two monitors :tt2:
tom_gr7
Life Serving
3 Monitors LOL :p
hahah lol what size? would you be happy to get two now, then another later, as i wouldn't want to drop the spec too much to fund a third screen. easier to buy a new screen then upgrade parts if you get me.
also what games are you thinking of?
tom_gr7
Life Serving
I'd go for something like this, only has two monitors as I wouldn't want to drop the spec too much as a monitor is an easy add later as opposed to getting a lesser cpu or no ssd.
2nd Hard Disk
Network Facilities
NO OFFICE SOFTWARE
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£139)
2nd Monitor
Quantity
1
Price: £1,821.00 including VAT and delivery.
AwesomeDude
Thanks for the Reply tom Really appreciated, I'm looking for 3 22" inch Screens to Play:
Crysis warhead
Bf3
Skyrim
Minecraft (LOL)
crysis 2
Mass effect 3
Hopefully All Maxed out :D
tom_gr7
Life Serving
Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) + HD Graphics
Network Facilities
NO OFFICE SOFTWARE
Monitor
2nd Monitor
3rd Monitor
Quantity
1
Price: £1,736.00 including VAT and delivery.
But I would discuss with pcs what eyefinity display port adapters you will need and what would be best suited. I would think two mini display port adapters, but check with pcs.
AwesomeDude
Tom thats a Great Spec thanks But I just Measured My desk and found it can only hold 2 22" So I can go back up to the i7 2600 :)
tom_gr7
Life Serving
ah damn mate, what about this then, a beefy cpu cooler! and a huge 27" screen!
2nd Hard Disk
TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39)
Network Facilities
NO OFFICE SOFTWARE
Monitor
IIYAMA E2773HDS 27" LED WIDESCREEN, HDMI/DVI-D HD1920x1080 (£239)
Quantity
1
Price: £1,802.00 including VAT and delivery.
