Hi there, so running icue all fans curves set up ok, but i am finding icue a little bit of a pain now and again . It will sometimes disconnect aio for a split second and connect back, this can happen quiet a lot, and sometimes not at all .
I have seen there are some issues with this software from what i have been reading. I was able to turn off icue and the cooler fan profile works ok without icue running . But the case fan profile does not work and the case fans just spin up very high and very loud when icue is off
I then thought ok, i will go into the bios to set a curve for the case fans . The case fans are not reacting to anything i do in the bios . i am sure they are identified as chass 2 in bios and i have chass 1 as well, which is the rear case fans and i can change that as much as i want in the bios .
Are the case fans not responding in bios because they are connected straight to the corsair commander , and icue is only way to control them , do i need to remove the cable from the commander and plug into motherboard so i can set fan curve in the bios for these fans . If so can someone help me with the procedure for doing this please. Ie where on motherboard would i connect them too please ? Thank you very much
AMD Ryzen 9 5900X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4)
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Keyboard & Mouse
Corsair K55 RGB PRO Gaming Keyboard (UK)
Promotional Item
Get Battlefield 2042 with select GeForce RTX™ 30 Series GPUs
Welcome Book
Logo Branding
PCSpecialist Logo
Keyboard & Mouse
Promotional Item
Welcome Book
Logo Branding
PCSpecialist Logo
