Fan question
VanBoon
Hi all,
Got my new PC. Today and it's superb. I got the PCS Malestrom case. But the large side fan wa not connected. I've connected it myself but I was wondering why there are 2 connectors? I've only used the one with the pins. Is this correct?
VanBoon
There are two white connectors on the big side fan. One with 4 pins and one with 4 holes. I pluged the 4 pin one into my power supply. It works fine and LEDs work also. Just wondered what the other connection was for?
Corfate
I have no idea, why not try it out? Im sure it won't explode :p If it does, don't blame me.. bloody pixies
VanBoon
There is nowhere to plug the 4 holed connection into. I'm sure 1 connection to the PSU is enough for a fan?
vanthus
Member Resting in Peace
Could be be a pass through connector, allowing you to daisy chain another fan from the same power supply cable/connection.
