nikipaprika
GAME MAX FALCON BLACK GAMING CASE (RGB LED)
Intel® Core™i7 Six Core Processor i7-8700 (3.2GHz) 12MB Cache
ASUS® TUF Z370-PLUS GAMING: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE DDR4 2133MHz (4 x 4GB)
4GB NVIDIA GEFORCE GTX 1050 Ti - DVI, HDMI, DP
1st Hard Disk
500GB WD Blue™ 3D NAND 2.5" SSD, (upto 560MB/sR | 530MB/sW)
2nd Hard Disk
1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
this is the first build in quite a long time, the last pc i bought from pc specialist would be all the way back in 2009! i am currently using a pc a friend gave me that is about 6 years old now, and while it does most jobs pretty dandy, it doesn't do so great when i would like to do more.
i'm mostly looking for a gaming pc, and to get a future proof build that i can upgrade at a later time if necessary. not looking for something super top spec but something that still handles well. i would like to be able to record and stream games at a fairly high quality. i am also interested in animation and video editing, and down the line may be using the likes of toon boom harmony, and i already have adobe after effects.
for my budget i really don't want to go over £1,200.
have been lurking earlier and heard that intel will possibly be releasing new CPUs/MoBos, and was wondering if i should hold off for a bit and see if i can get more value out of the new kit?
1st Hard Disk
2nd Hard Disk
