Looking to build a high-performance gaming PC with flexibility in what it can run, i.e. I won't be running Battlefield 4 on max settings, but I don't want to struggle with any high rendering games. No particular budget, I'm willing to spend whatever to get what will make this. Any feedback is appreciated, particularly anything I may have misunderstood, anything you wouldn't/would recommend, potential drawbacks and anything I may have missed. Thanks in advance!
TL;DR - Gaming PC, flexible budget, whatever feedback you can think of.
Intel® Core™i7 Six Core Processor i7-5820K (3.3GHz) 15MB Cache
COOLERMASTER CM STORM ENFORCER - GAMING ENTHUSIAST CASE
ASUS® X99-S: ATX, HSW-E CPU, USB 3.0, SATA 6 GB/s
16GB KINGSTON HYPER-X PREDATOR QUAD-DDR4 3000MHz X.M.P (4 x 4GB)
2GB NVIDIA GEFORCE GTX 750 Ti - DVI, mHDMI, VGA - 3D Vision Ready
1st Hard Disk
2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
1st DVD/BLU-RAY Drive
Corsair H60 Hydro Series High Performance CPU Cooler
Extra Case Fans
2 x 12CM Black Case Fan (configured to extract from rear/roof)
WIRELESS 802.11N 300Mbps PCI-E CARD
Price was £1,499, bearing in mind I intend to purchase a Roccat Isku keyboard and 23.6" monitor with this which affects the price.
1st Hard Disk
Extra Case Fans
