Finally decided to upgrade from my knackered old HP laptop and have spent the last few days obsessing over details of a few laptop builds as I want to get it just right.
What I'm after: Needs to be able to capture games via FRAPS and my PVR smoothly, and needs to be a video rendering/editing and Adobe Suite beast for my Youtube channel work (Premiere Pro is my most used program, with HD 60fps hour long videos to render). Game wise I don't play a lot of the more intensive AAA games but being able to run a smooth 60fps 1080p on stuff like Sonic Generations at the least would be great.
Not sure if this is possible with this high-spec laptops, but I need one that has a pretty quiet fan, or at least only makes noise if I am playing high-end games, as I do a lot of let's playing with a mic that picks up the fan noise on my current one. I know this is probably a tall ask though.
Budget: Up to around £1400
The laptop configs I've been tinkering with are the 17.3" Defiance, the 15.6" Defiance and the 15.6" Vortex IV.
Graphics: Going with the GTX 970M - 6.0GB DDR5, which they all have. The 980M takes them all above my budget.
RAM: Been sticking with 16GB Hyper-X Impact so far, double my current set up. Any more would be overkill correct?
Storage: Currently have a 1TB Samsung 850 EVO SSD, SATA 6Gb/s in all of the configs. Costs a bit more but one big SSD would be better than a 1TB HDD and a smaller SSD or would it? Again thinking of video rendering speed.
17.3" Defiance:
CPU: i7-4720HQ (2.60GHz, 3.5GHz Turbo)
- Easily the cheapest of the three configs at around £1300 so far.
- 4 x USB 3.0 ports (1 x powered, 1 e-SATA combined)
15.6" Defiance:
CPU: i7-4870HQ (3.7GHz Turbo, Iris™ Pro)
- Thinnest and lightest 2.5kg
- Config currently £1420
15.6" Vortex IV:
CPU: i7-4810MQ (2.80GHz) - according to CPU boss the best of the three?
- The CPU and GPU are apparently not soldered in, meaning I could upgrade or repair in future.
- Smaller width and length
- Includes a Subwoofer
- 3 x USB 3.0 PORTS + 1 x USB 2.0 PORT
- Only one that supports a DVD drive though I could always just get an external anyway.
- Includes Firewire port: could be useful in future for camera work.
- Most expensive config at the moment £1480
I can post the full configs if needed. Any advice at all on any of these elements (especially the storage as I have never had an SSD before) would be brilliant. So far I'm leaning towards the Vortex IV but not 100% sure yet.
17.3" Defiance:
15.6" Defiance:
15.6" Vortex IV:
