RMS Oceanic
Hi folks, my current PC is getting long in the tooth, so I've decided to bite the bullet and replace the whole thing.
Use cases: Consistent but not necessarily highend/max settings gaming, office work, media storage/playback, occasional video editing.
Current Monitor: Samsung S27AM500NR
Budget: ~£1600-1700
With a lot of thought I have come up with the following specs:
PCS ELEMENT CASE
Intel® Core™ i5 10-Core Processor i5-12600K (Up to 4.9GHz) 20MB Cache
ASUS® PRIME B760-PLUS D4 (LGA1700, DDR4, PCIe 5.0)
32GB PCS PRO DDR4 3200MHz (2 x 16GB)
16GB AMD RADEON™ RX 7800 XT GAMING - HDMI, DP - DX® 12
4TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
DVD/BLU-RAY Drive
16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW & SOFTWARE
PCS FrostFlow 100 V3 Series High Performance CPU Cooler
2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
Windows 11 Professional 64 Bit - inc. Single Licence
How does this look? Is anything in particular looking like overkill? Is there any experience on whether this would be a noisy assembly? Is the cooling I've selected adequate?
Also side query, does anyone know if Windows 11 is installed in a manner that doesn't require a Microsoft Account? If at all possible I'd like to continue my current practice of using a local account only, and would appreciate knowing the feasibility/pitfalls of this.
Budget: ~£1600-1700
PCS ELEMENT CASE
DVD/BLU-RAY Drive
