First serious desktop, help?
TheGaelicBrit
I ordered a low-mid Laptop to handle gaming from PCS 5 years ago now; feels like a different lifetime. I, admittedly, know how to use computers but not how a lot of them work, orrr really how to handle them without videos and guides. But after extensive use, this thing is barely holding together; My bad, I know.
So I'm biting the bullet and upgrading to a proper desktop, I've been going over YouTube channels (I'm sure folks here will know them) and looking at advice from mods here in the forums and put together this rig. But I need any advice on where I should cut back, consider different options or will there be compatibility issues. Thanks for the help.
Budget - I am aiming to keep it between £1500 - £1800 (AFTER VAT!) if I can, 2k is the hard cap of this and the more south the better
Monitor - Right now I do not have one, what is left over from my budget will be used to add one to my order. Advice on which to pick out would be appreciated.
Uses - Gaming and Streaming; Strategy games (Total War, Civilization etc) RPG: The Witcher 3, Dragon Quest 11, Dragon Age: Inquisition. And some light Apex Legends on the side, for personal playing.
(Current price: £1,692.00 including VAT and Delivery)
COOLERMASTER MASTERCASE H500 ARGB GAMING CASE
6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
1TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 1880 MB/W)
Ok will thi8s be used for anything other than gaming, such as streaming or editing videos, can you also please post the configuration link that you'll find at the bottom of that spec as this needs some work doing on it
Ok this a nice 1440p system that should you nicely paired with a samsung Odyssey G5
12GB AMD RADEON™ RX 6700 XT - HDMI, DP - DX® 12
Firefox™
Price: £1,783.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/fTKu8WaRuY/
Solid build by Martin, only thing I'd suggest if you can find the extra £25 go for the 980 Pro M2 SSD as opposed to the 970 Pro M2 SSD. Just faster is all
yeah i had the 980 in originally, but thought i might be getting a bit tight on the budget so changed to the 970
TheGaelicBrit
I can definitely try and squeeze it in, for sure. Really the buffer between the 1800 and the 2k max cap is for the monitor. And to try and keep it reasonable. If I go too much 'little more here, little more there' I've hit almost 2500 before and that'll set me back more then I have saved up.
I can definitely drop the extra for the 980 Pro though. This looks real nice, thanks for the help.
This'll be my first time going AMD for CPU, but I just hear right now it's just the better option of the two.
CPU wise yes it's no competition. GPU wise I think Nvidia are still out in front but AMD have closed the gap massively with the past two gens of cards
You're welcome, when i was speccing it i was thinking about £300 for monitor, which is round the figure that the G5 sits, and take it from me gaming on that monitor is really nice.
The reason i put the 6700xt in is that the best nvidia card for 1440p is the 3060TI which is out of stock with no indication of when it's going to be back in stock
TheGaelicBrit
It does look like a heck of a monitor, for sure. I'll definitely keep an eye on it and hold on to the leftover of my budget, get the rest together and plum for the G5.
I do gotta ask why the change from the Nvidia to AMD GPU? I know both are pretty scarce giving the whole situation right now. I'm not saying I disagree, just curious.
AMD GPU is 1440p whereas the 2060 is only 1080p
If you wanted to go Nvidia and didn't mind waiting, I can personally recommend the 3060Ti. Don't know when they'll have stock again though
If you wanted top end 1440p you could smash your budget and go for a 3070
See my edit above, basically the normal 1440p card from Nvidia is the 3060 Ti and it isn't available on the configurator
TheGaelicBrit
Ahhh I see.
You can tell I've been a low-budget gamer for a while, I'm not clued in on the 1080-1440p stuff. I'll be glad to have something that'll run. This is my first step up to something a bit more heavyweight.
Ahhh I see.
You can tell I've been a low-budget gamer for a while, I'm not clued in on the 1080-1440p stuff. I'll just like to have something that'll run. This is my first step up to something a bit more heavyweight.
Well any questions fire away mate, this is honestly the first generation where the jump to 1440p and even 4K is possible. With affordable GPU's and Monitors that don't cost your first born child. Hasn't really been a thing before now
Think of it this way though 1080p is about to be obsolete
TheGaelicBrit
Obsolete? Oof.. alright, do not ask me what I'm using right now then or you might cry. Let's just say I'll be going up like.. 3 generations of GPU with this.
The power supply seems quite a leap up too, is the jump from 550 to 850W necessary?
The reason for the 850W PSU is to give you head room for upgrading GPU's etc during the life of the PC, which should be 7-10 years with just a couple of GPU upgrades in that time
TheGaelicBrit
Ahh, okay, that's why I went 550 rather then the 450 the guide was initially suggesting, but yeah I see what you mean, it'd be used up quick with newer GPUs right?
Oh and which of the SSDs should I put the OS on? The 980 Pro?
TheGaelicBrit
Alright, thanks a lot. I think that just about does it. This is looking pretty awesome and I'm excited for this thing. Thank you Martin, I appreciate all the help.
