I did see that it had no pre order only status on it, but for me it's adding £142 Inc VAT...As the 3070 is a pre-order card the time they quote won’t be accurate, although from memory the 3070 turn around times are pretty good, I reckon you’d be looking at a calendar month or two. Or if you had an extra £40 To spend you could swap to the 3070TI which currently doesn’t have the pre-order status so the time they quote would be accurate- although that would rely on it staying on non pre-order until your build slot.
Is the Ti version really worth going for over the standard 3070. I've heard that it's not worth the extra and you're better off value wise with the 3070.
