Fortnite - Help
Arif
Hey ive been trying to install fortnite on this new micro sd card i got since my laptop storage is gone. I installed the epic games launcher fine. When i pressed install it showed downloading - and the percentage but when it got to 100% it went to installing- and the percentage.
But fortnite is 45 gb but when i pressed downloads it showed 85 being the full thing. Once it installed to 100% it said, Instal Failed. I checked why and it said the current folder was corrupted so i did it again but put (x86) in the install location. It was going fine until it restarted from 68% to 0%. From then on i cant install fortnite. Does anyone know what to do or know what the problem is.
Is this a PC Specialist laptop you’re issues with?
Why is your SSD full? How big is it? Have you considered removing some stuff you don’t use?
