Hi all,
Around 4 and a half years ago now I took the plunge and ordered my first ever gaming pc having been a console gamer all my days. I didn’t have much of a clue (still don’t) about all the different components etc, all I knew at the time was that I wanted a good pc to play Fortnite on and after a bit of research managed to get myself one that done the job. Specs as below:
CORSAIR CARBIDE SERIES™ 275R TEMPERED GLASS GAMING CASE
Intel® Core™ i7 Six Core Processor i7-8700 (3.2GHz) 12MB Cache
ASUS® TUF Z370-PLUS GAMING II: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
6GB NVIDIA GEFORCE GTX 1660 - HDMI, DP - GeForce GTX VR Ready!
256GB INTEL® 760p M.2 NVMe PCIe SSD (up to 3210MB/sR | 1315MB/sW)
500GB SEAGATE BARRACUDA 2.5" SSD, (up to 560MB/sR | 535MB/sW)
PCS FrostFlow 120 Series High Performance Liquid Cooler
WIRELESS 802.11 Gigabyte GC-WB1733D-I AC 1734Mbps + BT5 PCI-E CARD
I’m now looking to make the switch completely from console to pc and need some advice on how my build stacks up these days for what I’m looking for and whether I should start completely from scratch or if there’s some components from my original build that are still worth using?
See below for my needs and further info:
Main goal - To have a pc that’s capable to hitting around 140fps on first person shooters with graphics set to a decent level.
Uses - I’m looking to use it mainly as a gaming pc for triple A titles (mostly first person shooters) with the ability to use it for work (emails and browsing) and music production (FL studio).
Monitor - I currently have a 1980x1080 144Hz monitor. I’m happy with this for now but I’d like to build my pc with 1440p gaming in mind so I can upgrade this at a later stage.
Budget - My max budget is around £1,200 for a new build if it’s the best way to go.
Questions that I need help with:
1. Is my build of a good enough standard that I can upgrade a couple of components to get it where I need it to be?
2. If the answer to 1 is yes then which parts should I upgrade and to what?.
3. If the answer to 1 is no could you comment a build that’s capable of meeting my requirements for my budget?
Appreciate any help in advance.
Thanks,
Thanks,
