Front Panel Audio Connection
barhut
My front panel audio connection is being really strange. It keeps popping up saying "you have just plugged in a device" then "you have just unplugged a device" . I tried connecting my turtle beach headset and it just keeps connecting and disconnecting by itself. Im beginning to lose patience. Any help would be great
barhut
This is my spec:
Intel® Core™i5 Quad Core Processor i5-3570 (3.4GHz) 6MB Cache
ASUS® P8H77-M: M-ATX, DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX™
2GB NVIDIA GEFORCE GTX 660 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk
1st DVD/BLU-RAY Drive
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
INTEL SOCKET LGA1155 STANDARD CPU COOLER
Network Facilities
1 x 2 Metre UK Power Cable (Kettle Lead)
NO OPERATING SYSTEM REQUIRED
NO OFFICE SOFTWARE
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 12 NOON)
Quantity
1
Are you sure you have all the right drivers installed? Particularly the one for your audio card? If you have I'd give PCS a call, this sounds like it may be a hardware issue.
