Gaming rig ! please help
ShadowGaming
This is specs of a gaming rig i would like to buy and well i dont know how i can improve it or if it is good i would like to max graphics on new games such as diablo 3 guild wars 2 and make it a bit future proof (3-4) years, also my budget is around about £1500, this one is £1286 including VAT so here it is :
InWIN BLACK DRAGON RIDER GAMING CASE
Intel® Core™i5 Quad Core Processor i5-3550 (3.3GHz) 6MB Cache
ASUS® P8Z77-V: PCI-E 3.0 READY, WIFI, SLI, CROSSFIREX
8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
3GB AMD RADEON™ HD7950 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Memory - 1st Hard Disk
2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£46)
SPIRE THERMAX ECLIPSE II UNIVERSAL DT EXTREME CPU COOLER (£39)
Network Facilities
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£129)
tom_gr7
Life Serving
looks spot on mate, i'd get the 650w corsair psu, energy efficient, reliable and looks ten times visually better than the non branded versions.
also get the warranty for a fiver. :)
ShadowGaming
Is the RAM ok on this because the 16gb of ram is not much more and i plan to record videos for youtube of these games ?
tom_gr7
Life Serving
8gig is fine, although, if you will be editing these videos as well? Then yes 16gb will be beneficial.
baron75mk2
Banned
Hi there , im not farmiliar with the two games you have mentioned , but if your after high fps in general ( 60fps+ ) then i would suggest going with the radeon HD 7970 ( i presume you prefer ATI that is ) , this will give lots more performance in terms of fps that is , also i would go for the biggest psu you can possibly afford , this will give you plenty of headroom for multiple gpu setups in the future.
Some might call it overkill but there is nothing like not having to worry about power requirements & having more than you need results in a more stable & smooth power supply when the PSU is taxed - essential for SLI / crossfire setups ( i personally would reccomend SLI over crossfire myself)
