General Use : Light Gaming
overthehill
Hi, I have a budget of about £800 , this is what I settled on . As the title says general PC stuff & some light gaming mostly Football Manager . Any suggestions or improvements that could be made would be gratefully received . Thanks
InWIN GT1 BLACK GAMING CASE
Intel® Core™i5 Quad Core Processor i5-6400 (2.7GHz) 6MB Cache
ASUS® H110M-R: Micro-ATX, DDR4, LG1151, USB 3.0, SATA 6GBs
8GB HyperX FURY DDR4 2133MHz (2 x 4GB)
8GB AMD RADEON™ RX 470 - HDMI, DP, DVI - DX® 12
1st Hard Disk
1TB SEAGATE 3.5" SSHD, SATA 6Gb/s 7200 RPM (64MB + 8GB SSD CACHE)
1st DVD/BLU-RAY Drive
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler (£19)
Creative Sound Blaster® Audigy™ FX OEM (£28)
Genuine Windows 10 Home 64 Bit - inc DVD & Licence (£89)
NO OFFICE SOFTWARE
Firefox™
Quantity
1
Price: £813.00 including VAT and delivery.
You could get the Hyperion Master off the review section here: https://www.pcspecialist.co.uk/reviews/
It has a fixed price of just under £800, but has a 120gb SSD + 1 TB HDD, a Z170-P motherboard (more features and options for upgrades), and an RX 480 8gb GPU. Plus an i5 6400 and 8gb RAM, like your spec. Even has the same case. So it's basically an upgrade for a lower cost. :)
It doesn't have a sound card, but tbh you're not likely to get much benefit off a basic sound card for the uses you've put above. The onboard audio should be more than fine.
Source:
KitGuru.net
Model:
Hyperion Master
Date Added:
05-07-2016
Price:
£799
URL:
View Review Here
Quotes:
"...it is clear that AMD is back in the fight and is addressing the lower end of the market, an...
ASUS® Z170-P: ATX, LG1151, USB 3.0, SATA 6GBs
8GB AMD RADEON™ RX 480 - HDMI, 3 x DP - DX® 12
FREE BATTLEFIELD 1 DISCOUNT CODE with AMD RX 480 GPUs!
1[SUP]st[/SUP] Hard Disk
120GB HyperX SAVAGE 2.5" SSD, SATA 6 Gb/s (upto 560MB/sR | 360MB/sW)
2[SUP]nd[/SUP] Hard Disk
1TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
1[SUP]st[/SUP] DVD/BLU-RAY Drive
PCS FrostFlow 120 Series High Performance Liquid Cooler (£39)
Quantity
1
overthehill
Thanks for taking the time Oussebon repped . Price has gone up since then £935 inc VAT . Don't think I will need a second hard disk , nor thermal paste or the higher power supply 450 is enough . After a bit of tinkering the price was still £881 . Have taken your advice though & ditched the added sound card from any future modifications
The price is still £799. :) You need to use the
button on the review page https://www.pcspecialist.co.uk/reviews/ to keep the fixed price.
If you press
even without changing anything, the price will go up to the regular non-discounted level of over £900. (There should be a little pop up that warns you).
You can press the order button without being asked to enter payment details or anything, so you can test it out perfectly safely.
And ty for the rep btw, much appreciated.
overthehill
Seagate SSHD
Was configuring a new PC , got to the Hard Disk , had chosen The Seagate SSHD 1TB , then checked the 2TB which is only about £20 more expensive , was expecting a bigger price difference so swapped , looks a good deal to me .
If your budget is still in the £800 region I'd still suggest the Hyperion Master tbh. If your budget has increased, set out what it is and we can suggest some options from the H110 chipset build.
overthehill
InWIN GT1 BLACK GAMING CASE ( Corsair 03 Compact Red LED )
8GB AMD RADEON™ RX 470 - HDMI, DP, DVI - DX® 12 ( 4 GB Radeon RX 460)
1st Hard Disk
1TB SEAGATE 3.5" SSHD, SATA 6Gb/s 7200 RPM (64MB + 8GB SSD CACHE) ( Samsung 500 GB 750 SSD )
Added a 2nd Hard Disk mostly for music
2nd Hard Disk ( 500 GD WD )
Creative Sound Blaster® Audigy™ FX OEM (£28) ( replaced with onboard card )
NO OFFICE SOFTWARE
Firefox™
Quantity
1
( £ 809 )
Made a few changes in bold , still around the £800 mark
