Graphics card problem (screenshots attached) - please help!
MaltonSeadog
Hi all,
The other day, my 2-year old PC Specialist computer loaded up fine, but after playing a game for a while, I began to experience flickering of the screen which corrected itself.
When I next switched the PC on, I was greeted with the screenshots attached. After logging in, I got a plain black screen with no functionality at all, meaning I had no option but to switch off.
I tried running in Safe Mode, and this was absolutely fine, suggesting it's a GPU problem perhaps?
Opened up the PC to clean the dust filters and make sure everything was plugged in OK, and when I switched it back on, it seemed to be fine and worked well for a few days.
However, after playing a different game today, I got the odd split-second flicker, and sure enough upon rebooting the PC, I had the horizontal lines again.
I'm currently using the PC having cleaned it out (again) and had a play around inside, but the third screenshot shows I'm having problems with menus etc. All black until I roll my mouse over it, which reveals the options.
I downloaded up to date GPU drivers a few days ago, too.
My full specs are as follows:
Intel i7-3770 @ 3.4Ghz (8 CPUs)
16GB SAMSUNG DUAL-DDR3 1600MHz (4 X 4GB)
2GB AMD RADEON™ HD7850 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER
Genuine Windows 7 Home Premium 64 Bit w/SP1
Any tips greatly appreciated.
The two games, out of interest, are Bioshock Infinite on full graphics, and Lord of the Rings Online on full graphics. The latter has always worked fine, but the former seems to be the cause of the initial problem despite my card being comfortably within its requirements. Indeed, I was running the game flawlessly on highest settings with a fantastic frame rate with no issues. It's when I closed the game down that the problem began.
vanthus
Member Resting in Peace
What's the best way to do this please? Never had to before.
Open the Control Panel
Select Programs and Features
Select AMD Catalyst Install Manager.
Click on Change.
Click on Next when prompted for the Welcome to the InstallShield Wizard for AMD Catalyst Install Manager,
Select Express Uninstall All Software,
Follow the on-screen directions and restart the system when finished
To verify that the graphics driver has been uninstalled, return to the Uninstall or Change a Program list and ensure that there is no AMD specific software listed.
If AMD specific software is still listed, remove any remaining AMD software components using the above process and restart the system when complete.
Download latest driver from here.
http://support.amd.com/us/gpudownload/Pages/index.aspx
MaltonSeadog
Click on Change.
Thanks a lot! Seems to have stabalised for now. I shall play games with baited breath and see if it's solved it!
