Hello Pc Specialist. I have bought my pc from you guys so im gonna first ask around here before i make wrong assumptions.
I've got a little problem with my Nvidia GTX 560 Ti, when im playing World of Warcraft or Starcraft 2 it really heats up (reaches about 89°C) and it start making a quite loud noise (the fan).
Ive got my pc for quite a while (4 months) and i am sure the card was not making this loud noise in the beginning.
Should i worry about it? Can i do something so it wont heat up?
Spec:
Case: COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Processor (CPU) Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) + HD Graphics
Motherboard ASUS® P8P67 PRO (NEW REV 3.0): USB 3.0/SATA 6Gb/s, CrossFireX™ & SLI
Memory (RAM) 4GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 2GB)
Graphics Card 1GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
Memory 1st Hard Disk 750GB WD CAVIAR BLACK WD7502AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Power Supply CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU
Processor Cooling COOLIT ECO A.L.C (ADVANCED LIQUID COOLER)
Network Facilities ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD
Monitor IIYAMA E2271HDS 22" LED WIDESCREEN, HDMI/DVI-D HD 1920x1080
Cheers.
Spec:
Cheers.
