help a girl out D:
gamergirl2001
hii - new to PCS and want to check if these specs are okay for games like valorant, tarkov, squad, league of legends, dayz etc. i have a monitor that can hit 1440
PCS PRISM TG BLACK ARGB MID TOWER CASE
Intel® Core™ i7 12-Core Processor i7-12700K (Up to 5.0GHz) 25MB Cache
GIGABYTE Z790 GAMING X AX (LGA1700, DDR5, PCIe 5.0, Wi-Fi 6E)
12GB NVIDIA GEFORCE RTX 4070 - HDMI, DP, LHR
Graphics Card Support Bracket
PCS GRAPHICS CARD SUPPORT BRACKET
1TB CORSAIR FORCE MP600 NVMe PCIe M.2 SSD (up to 4950 MB/R, 4000 MB/W)
2nd M.2 SSD Drive
Braided Power Supply Cables
CORSAIR Premium Individually Sleeved PSU Cable Kit Pro - Black
PCS FrostFlow 360 Series ARGB High Performance Liquid Cooler
ONBOARD LAN PORT
NONE OR ONBOARD Wi-Fi (MOTHERBOARD DEPENDENT)
Surge Protection
8 Socket 2m Surge Protector
FerrariVie
Super Star
A few comments about your build.. It is mostly good, however I can suggest 2 things:
1- Your choice of CPU is not the best value. If you're able to afford around $40 extra, I would jump to a newer gen 13700K. However, even better than that would be to use the 12700KF instead (same as your choice, but without integrated graphics) that is cheaper, and use that difference to bump the GPU to a 4070 Super.
2- Any particular reason why you have chosen an Intel build? $100 extra would give you the best gaming CPU on the market today which is AMD's 7800X3D, and you could pair that with an ASUS TUF Gaming B650-PLUS WIFI motherboard.
However, it is a though choice even for me between number 1 (12700KF + 4070 Super) and 2 (7800X3D + 4070). Either would be great, though. 😊
sck451
I'd want to ask precisely what monitor you have, @gamergirl2001. What make and model is it? Also, can you include the full specification including the price and the configuration link? And what's the budget?
Broadly I'd say it's not bad but you can probably do better for your money.
gamergirl2001
And the other questions?
budget for the pc would be 2k
sck451
Here's where I'd go for that budget and monitor:
FRACTAL FOCUS 2 ARGB GAMING CASE (BLACK) Good quality but reasonably priced case
AMD Ryzen 7 7800X3D Eight Core CPU (4.2GHz-5.0GHz/104MB w/3D V-CACHE/AM5) The best gaming CPU there is
12GB NVIDIA GEFORCE RTX 4070 SUPER - HDMI, DP, LHR A decent step up from the 4070 in your config
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) Boot drive
2TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 3325MB/sW) Big games drive
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET Overkill power supply, but it's efficient and quiet and has room for plenty of upgrades
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler All the 7800X3D needs to keep cool
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Price: £1,957.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/k7NNv06RbY/
