NathanCarley
So i bought a pc specialist pc, with windows 10 installed. I'm just wondering if i was to upgrade my Asus H110M-R Motherboard to MSI Z97s. Would everything still work fine & would i need to reninstall windows?
Why would you want to replace it with a motherboard for an older family of CPUs (which won't work with whatever you have now). And you'd need new RAM too...Asus H110M-R Motherboard to MSI Z97s
Why not buy a Z170 or Z270 mobo if you want to upgrade?
Maybe give a bit of context about what you're trying to achieve by changing the motherboard as well. What does the current one not do for you?
Was just going to go for a black & white theme, working from the ground up. Mb to cpu & then watercooled..
My Pc Specs: https://www.pcspecialist.co.uk/forums/showthread.php?52529-%A3800-Intel-Gaming-PC-Help-please
(NZXT S340)
Intel® Core™i5 Quad Core Processor i5-7500 (3.4GHz) 6MB Cache
ASUS® H110M-R: Micro-ATX, DDR4, LG1151, USB 3.0, SATA 6GBs
8GB HyperX FURY DDR4 2133MHz (2 x 4GB)
6GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
1st Hard Disk
1TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
1st DVD/BLU-RAY Drive
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
Genuine Windows 10 Home 64 Bit - inc DVD & Licence
Quantity
1
Price: £804.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-home-office-pc/xYNCs22AaM
So this is your spec:
Your CPU is a Kaby Lake CPU. That means it will only work on motherboards with Socket 1151. The Z97 is Socket 1150. Which means that to use it you'd have to buy a CPU from 3 generations ago.
Watercooling is only worth it if you're overclocking.
The CPU you've bought is locked, and the H110M-R mobo doesn't support overclocking. Which means watercooling isn't a good use of money.
You've literally just spent about £200 on a CPU 6 weeks ago, and you're already considering replacing it and the motherboard... In all candour I think you need to rethink this one.
What should i upgrade then?..
