Help building a PC
ahinks
Can anyone help me spec out a gaming PC? My current PC is very outdated and it’s time to build a new one but have no experience or knowledge with this. I only really play warzone/fps games - and have a budget of around £2k. Want best performance I can get for that price. Any help would be appreciated
Ekans2011
Hello, what monitor are you currently using?
ahinks
Hi all, just wondering if someone could take a look through these specs and see if they are good enough to run or if I can change anything to make it cheaper?
FRACTAL DESIGN TORRENT RGB MID TOWER CASE
Intel® Core™ i7 20-Core Processor i7-14700K (Up to 5.6GHz) 33MB Cache
ASUS® ROG STRIX Z790-F GAMING WIFI II (LGA1700, DDR5, PCIe 5.0, Wi-Fi 7)
16GB NVIDIA GEFORCE RTX 4080 SUPER - HDMI, DP, LHR
4TB CORSAIR MP600 PRO NVMe PCIe M.2 SSD (up to 7000 MB/R, 6850 MB/W)
2TB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
CORSAIR iCUE H150i ELITE CAPELLIX XT RGB High Performance CPU Cooler
ONBOARD LAN PORT
Microsoft® Edge
Price: £3,020.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z790-ddr5-pc/FdDSRbNC7n/
sck451
What's it for? What monitor do you have? What is the budget?
Also, you have a weird SSD setup there -- any particular reason?
ahinks
Mainly for gaming, I have an LG ultra gear 27GL850-B but I would upgrade my monitor along with the PC, it would probably be around 2.5/3k.
If I’m honest I don’t know much about PC’s so not sure what I would need, would you suggest a different set up for the
sck451
Awesome. I wouldn't change that monitor unless you specifically want to: it's a good display, even if not the most current. If you do want to change it, I'd think about what you're going to get before you buy a system, as really you want them to be a good match.
I'm going to presume for now that you're going to stick with the LG. If you want to change it, it would probably only need to be the graphics card that might want reconsidering.
First, the case. The Torrent is a great case, but it's designed for air cooling. It's not really suitable for a liquid cooling setup. So I'd either change the case (maybe the 5000X instead?) or the cooler (to a good air cooler). Personally I love the Torrent so I'd go for the latter, especially as the 7800X3D I'm suggesting really doesn't need a 360mm AIO to keep it cool!
Then I'd go in quite a different direction with an AMD CPU-based build, as it's overall cheaper, better performing, more efficient and cooler.
AMD Ryzen 7 7800X3D Eight Core CPU (4.2GHz-5.0GHz/104MB w/3D V-CACHE/AM5) The best gaming CPU there is
ASUS® TUF GAMING B650-PLUS WIFI (AM5, DDR5, PCIe 4.0, Wi-Fi 6) Sufficient motherboard
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB) All the RAM you need
16GB NVIDIA GEFORCE RTX 4070 Ti SUPER - HDMI, DP, LHR You don't need a 4080 Super for 1440p 144Hz - the 4070 Ti Super is a stupid name but a decent value card
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) Boot drive
4TB CORSAIR MP600 PRO NVMe PCIe M.2 SSD (up to 7000 MB/R, 6850 MB/W) Biiiiig games drive
CORSAIR 1000W RMx SERIES™ - MODULAR 80 PLUS GOLD, ULTRA QUIET Plenty of power supply capacity to allow future upgrades
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler Plenty for the 7800X3D
ONBOARD 2.5Gbe LAN PORT
Windows 11 Home 64 Bit - inc. Single Licence If you already have a Windows licence you could transfer it and save ~£100
Microsoft® Edge
Price: £2,509.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/scgjgCVZhR/
