Hi all,
I’d appreciate some help in creating a spec for a desktop PC and monitor please. I don’t have the required knowledge in this area to feel confident choosing the correct or most suitable components.
The software usage is as follows:
Carveco - CAD/CAM, creating 3D reliefs and models, 3D sculpting. I often use a drawing tablet with this app.
Fooocus - Local Stable Diffusion AI image generation. Apparently requires NVIDIA GPU for optimum results.
EzCad3 - Laser control. Slicing .stl models.
I won’t be gaming, editing video etc.
Budget - £3.5k
Monitor - open to suggestions. Maybe 27” in size.
I’m currently running the above on a fairly old Acer Predator gaming laptop, hence the decision to upgrade. This will be a work/business machine, so efficiency and speed are priorities, particularly with IA image rendering and 3D sculpting.
Suggestions regarding a suitable spec most welcome. Thanks in advance.
Budget - £3.5k
