Hi all
I have put together a desktop pc for use with Adobe Photoshop cs5 but i'm not 100% convinced I have selected the right spec as my knowladge on building pc's is not great
What I really want is a well balanced, quite but fast computer that can handle cs5 without any lag
Any advice is appreciated
CORSAIR GRAPHITE SERIES™ 600T GAMING CASE (£139)
AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4N98TD EVO: DDR3, 2-Way SLI, SATA 3.0GB/s
1GB NVIDIA GEFORCE GTX465 GDDR5 PCI EXPRESS - DirectX® 11
Memory - 1st Hard Disk
150GB WD VELOCIRAPTOR® SATA 3-Gb/s, 16MB CACHE (10,000rpm)
2nd Hard Disk
80GB Intel® X25-M 2.5" SSD (34nm / upto 250MB/sR | 70MB/sW)***SPECIAL***
1st DVD/BLU-RAY Drive
10x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£89)
2nd DVD/BLU-RAY Drive
10x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£59)
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply & Case Cooling
CORSAIR 750W PSU (TX750) 80+ ULTRA QUIET (£90)
STANDARD AMD CPU COOLER
Network Facilities
NO OFFICE SOFTWARE
Monitor
IIYAMA E2271HDS 22" LED WIDESCREEN, HDMI/DVI-D FULL HD 1920x1080 (£149)
2nd Hard Disk
Network Facilities
NO OFFICE SOFTWARE
Monitor
