To take a screen shot, there should be a button called 'Print Scr' or 'Prnt Scrn' on your keyboard. Sometimes the button is a dedicated button, other times it requires you to push the 'Fn' key. As it's a laptop you would probably have to push the button to the right of the Ctrl key labelled 'Fn' and then push the 'Print Screen' button at the same time. Usually the keys are colour coded to help.
Once you have pushed this, the screenshot should be copied to your clipboard. You can then paste this into MS Paint and print it from there (Ctrl+v). Or you can paste into a word document and print from there.
Thanks Nathan. Yup got the Fn & Prt Sc buttons (in blue), but I have no idea where "clipboard" hides. As I said idiot outside :wacko:Regards.
Hehe, do not worry, you haven't annoyed anyone, asking questions is the only way to learn and you asked with politeness so it's all goodHi RAKK Master Moderator, thank you for your comprehenive answer, I do not wish to anoy you. It works perfectly thanks again. Job done!! Best Regards.
