University. Around £1000 to blow. Big gamer. Here's what I was thinking:
Optimus II: 15.6" with...
Intel® Core™i7 Quad Core Mobile Processor i7-2760QM (2.40GHz) 6MB
4GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 2GB)
nVIDIA® GeForce® GT 555M - 2GB DDR3 Video RAM - DirectX® 11
750GB WD SCORPIO BLACK WD7500BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
GIGABIT LAN & WIRELESS INTEL® ADVANCED-N 6230 (300Mbps) + BLUETOOTH
Upgrade to 62.16WH 6 Cell Lithium-ION Battery (£39)
(and all other options as standard)
for £942.00 inc VAT. Which I like.
First off, some questions about that spec:
1) I read that the Optimus II casing feels a bit cheap and plastic. I really don't mind this, and much prefer a dressed down laptop to those big show-off Alienware ones. However, is there an increased danger of it breaking without the £79 Matte option?
2) 4GB RAM - is it better to have 2x2GB or 1x4GB?
3) What is the difference between a 150Mbps Gigabit LAN wireless and the 300Mbps one? 'Faster' internet?
4) How much more juice do I get from a 62.16 battery over the 48.84 one? Enough to warrant the £40 more?
5) What's the difference between 64-bit and 32-bit Windows 7?
Secondly, the 'other option'. The VortexII 15" laptop with a worse processor (Intel® Core™i5 Dual Core Mobile Processor i5-2450M (2.50GHz) 3MB) but better GPU (1.5GB nVIDIA® GeForce® GTX 560M - DirectX® 11). While I'd get a better battery and webcam (not too bothered), I'd have to get a worse HDD and it would set me back a hefty £971.
I did some research using this awesome site - http://www.passmark.com/index.html
OptimusII: CPU - i7-2760QM (2.40GHz) is 37th best CPU
GPU - GeForce 555M is 123rd best GPU
VortexII: CPU - i5-2450M (2.50GHz) is 197th best CPU
GPU - GeForce 560M is 85th best GPU
As you can see, the OptimusII has a much, much better CPU, but a slightly worse GPU than that Vortex. I really like the Optimus, as it's cheaper and I can add more extras like better Gigabit and faster HDD and stuff - but (this is question 6) is the 555M a great deal worse than the 560M? I'll be looking to play games like Battlefield 3, Metro: Last Light, etc - most big releases that pack a visual punch (though I usually leave big RPGs like Skyrim to my PS3). So will I regret choosing the 555M? How well do you think I could run those AAA games? Basically - thr Optimus or the Vortex?
A lot of questions there - bit if you could leave clear answers it would seriously help me out. Thanks so much!
