HELP ME PLEASE webcam issues !!
TheDriftDuckTTV
Can anybody help me out please !!
Right so bassically i got my computer last year and have sort have been putting up with this issue as i havent found a solution anywhere but bassically ive tried everything
So when im on my pc built from here to these specs
PCS SPECTRUM RGB MID TOWER CASE
Intel® Core™ i7 Eight Core Processor i7-10700F (2.9GHz) 16MB Cache
GIGABYTE H510M H : Micro-ATX, DDR4, USB 3.2, SATA 6GBs
16GB Corsair VENGEANCE DDR4 2400MHz (1 x 16GB)
1TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY
PCS FrostFlow 100 V3 Series High Performance CPU Cooler
Welcome Book
Logo Branding
PCSpecialist Logo
I have a razer kiyo pro webcam and when im on the software that lets you see the camera its mint perfectly fine no issues i can stream onto youtube perfectly fine no issues with camera no glitching no nothing but asoon as i go on to streamlabs or obs it starts glitching all over the place ive tried allsorts of diffrent settings ive even tried going from windows 11 to windows 10 just to see if that changed anything ive tried all diffrent usb slots ive tried taking it back getting it exhanged for a diffrent camera (same make and model) ino its not the camera because ive even tried a logitech streamcam and it still douse the same with that.
ANY HELP WOULD BE SO MUCH APPRECIATED !!
TheDriftDuckTTV
thanks for the reply mate its not the razer and logitec software as it works on youtube for streaming but its somthing to do with obs/streamlabs i think but im not 100%
With OBS, I would have a look through the settings & resolution. Try dropping the resolution quite low and see if the issue disappears. Also, check if there is a hardware option for what generates the image. I would think hardware would be the best choice for that, but if it's already on hardware.... change it to software.
TheDriftDuckTTV
thankyou for the reply
ive allready turned the resolution down and it still douse it ive bin through most settings in streamlabs/obs and it nothing changes it
so like you said should i try the hardware to software change ?
Yip, definitely. Worth a shot.
