help please with htpc specs
tatooandy67
Hi all,
I'm not too up on current pc tech so would apreciate any help available with spec for htpc
my requirements are hdd around 4tb - I have a lot of ripped movies and music files,
light gaming, and possibly some music editing/recording - (guitar tracks through software called guitar rig - I have an external asio sound card which is perfect for this)
and usual pc stuff - internet, docs etc. I have a budget of around £700 - £800
I will be using 50 inch samsung plasma as a monitor and for sound I have a 5/7.1 av receiver.
Thanks in advance for your assistance
Teaz
Godlike
This spec will do all your requirements well for you :) it may be at the end of your budget but worth its performance for all your needs with plenty of storage.
COOLERMASTER ELITE 310 BLUE CASE
AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M5A87: AM3+ PLATFORM, DUAL DDR3,SATA 6.0GB/s, USB 3.0
8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
1GB AMD RADEON™ HD6850 - 2 DVI,HDMI, DP - DX® 11, Eyefinity 3 Capable
Memory - 1st Hard Disk
750GB WD CAVIAR BLACK WD7502AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk
2TB WD CAVIAR GREEN WD20EARS, SATA 3 Gb/s, 64MB CACHE
3rd Hard Disk
1st DVD/BLU-RAY Drive
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Network Facilities
Total: 802
Configure it here :)
vimto1
would it not be cheaper for him just to have 1x4TB HDD in stead of 2x2TB HDD's? It still fits his spec.
Teaz
Godlike
I would but apprently the a 4TB drive isnt stocked by PCS, ive only remeber seeing a 3TB max on the caviar green but they are out of stock right now im guessing since its not on the config. Plus it be nicer to even the drives out than having a whole when it comes to internal drives.
UndeadJack
Master Poster
Plus if 1 dies he has backup
