Help. Windows problem?
helhay
Hi I got a red and yellow windows error this morning. Now my screen has moving lines accross it that get worse when i move my mouse, monitor is working perfectly. Virus check came back clear. What can I do. Only had pc 2 days.
hillyhumbo
helhay
My son did not get a blue screen of death, he got a red and yellow windows error message, it went off too quick to read the code.
The home screen is on and can be seen but there are what looks like blurred lines of moving data running accross the screen over the top of it,
I tried to add a picture but it says it's too large and I don't know how to modify it
helhay
Can you please post the full spec from the order please? That way everyone knows what sort of build we're looking at.
Did you buy Windows with it or did you install your own copy?
helhay
Ok, I changed order before I got an updated spec list, so I made some changes before ordering. Which were to a cooler master liquid system, 1 Tera data instead of the 240 and windows 10 home to prof.
Silenced
Windows 10 Pro is not really needed. Unless you want BitLocker, Viridian , RDC and Business stuff.
helhay
I know I just wanted the best of everything I could afford for him, its the problem with the screen that i can't work out x thanks anyway
I
would do a full scan with malwarebytes.
Try uninstalling gpu drivers with ddu then reinstalling latest drivers from nvidia:
helhay
Done scans, and updates, changed monitor and different cables, reseated geaphics card, deleted it and re downloaded it. Pcspecialist think it may need a new graphics card or its a problem with motherboard?
Did you scan with malwarebytes?
Did you uninstall with ddu?
barlew
Godlike
I would be inclined to agree with them. That picture of your monitor you posted at the top screams hardware fault.
Best way to find out is disable the GPU and use onboard graphics (assuming you have onboard?) see if the fault replicates.
Rakk
The Awesome
The Ryzen 7 3700X does not have an onboard GPU unfortunately so unless @helhay has another GPU to try this may be a tad tricky :(, but I'd be guessing a hardware fault from the picture as well :(
