Help with a Gaming pc build for about £450 - £500
Aimedaxis
Hi there, Im Looking to buy a gaming pc for about 450 - 500 pounds, however I do not know what I would need for a good build for that kind of budget, If anyone could design one for me it would be greatly appreciated, All I need is a quad-core pc with a decent graphics card, basic monitor (18 inches is fine) and windows 7.
Im ideally looking for a pc that can play at the very most Battlefield 3 on like medium settings I guess, also to render videos. Any help is greatly appreciated, thank you.
Thanks,
Kieran
mantadog
Superhero Level Poster
Just to let you know, i am not sure this spec will do what you want but it is the best you are going to get.
STYLISH PIANO BLACK ENIGMA MICRO-ATX CASE + 2 FRONT USB
AMD A4-3400 APU (2.7GHz, 2 Cores) & AMD Radeon™ HD 6410D Graphics
ASUS® F1A55-M LE: FM1 A-SERIES, SATA 3.0GB/s, USB 2.0
4GB SAMSUNG DUAL-DDR3 1333MHz (2 X 2GB)
1GB AMD RADEON™ HD6790 - DVI,HDMI,mDP - DX® 11, Eyefinity 3 Capable
Memory - 1st Hard Disk
250GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
1st DVD/BLU-RAY Drive
350W Dual Rail PSU + 120mm Case Fan
STANDARD AMD CPU COOLER
Network Facilities
Monitor
19" Widescreen TFT 1366 x 768 2MS, D-Sub, DVI, 18.5" Panel (£69)
Quantity
1
Price: £502.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/amd-llano-home-office/
I would really suggest you try and save up some more money if at all possible, you can't get a quad core setup and a GPU for that kind of budget. From looking at youtube, i have found people playing with a 6790 and a dual core intel processor, on something approaching medium settings, so it is doable. The video rendering will take a long time on that machine though, but it really is the best you can get for the money.
mantadog
Here is a base level gaming pc, quite a bit better overall. Thats the spec i would be aiming for i know it's a bit over your upgraded top end budget, but it's what i would advise if you can afford it.
If £600 is your limit drop the GPU to a 6850, not much slower and keeps you on budget.
mantadog
OOps, i might have been distracted in the middle of that post, or some glitch happened i was sure i posted them. Sorry!
something like this.
COOLERMASTER ELITE 310 BLUE CASE
AMD BULLDOZER QUAD CORE FX-4100 (3.60GHz/4MB CACHE/AM3+)
ASUS® M5A78L-M/USB3: M-ATX, USB 3.0, SATA 3.0Gb/s
1GB AMD RADEON™ HD6870 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan (£29)
Network Facilities
Monitor
Quantity
1
Price: £622.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/amd-bulldozer-top-spec-pc/
