Hi Guys,
So I have been looking to get into editing a little bit more seriously now, and the time has come to invest in a new computer…this begs the question Mac or cusom built pc?
Been looking at the 15″ macbook pro as it has the updgraded graphics card from the 13″, but could you guys advise me on whether or not this would be suitable? or should i go down the PC route which would provide a possibly better spec option.
Looking to use sony vegas pro and after effects mainly.
Would be using pcspecialist.co.uk if i can down the pc build route, so a couple of example build in the budget of the mac (£1600ish) would be good.
Cheers.
Cheers.
