Help with Graphics Card
oli090
I bought my pc a year ago now and im looking to get new monitors. I have a hd radeon 6770 graphics card and im wondering if it will be able to handle dual monitors at 1080p using HDMI. The monitor im looking at is a iiyama one which has HDMI. One of the pictures at the bottom is what my graphics card backports are. I need to also know what calbes and adapters i will need to buy to get this to work. Thanks in advance.
http://1.bp.blogspot.com/-S3j8eMdcO...adeon_6670_2_gallery_191833014296_640x360.jpg
http://www.amazon.co.uk/iiyama-X237...klight/dp/B005UK3K8O/ref=cm_cr_pr_product_top
Top link is Graphics card and bottom is tv im getting.
vanthus
Member Resting in Peace
Your graphics card has a DVI and an HDMI port as does your monitor,so all you should need is an HDMI cable and a DVI-D cable,I think a DVI cable is supplied with the monitor.
oli090
Will the quality be exactly the same as i dont want different resolutions and stuff or it will look weird?
vanthus
There should be no noticeable affect on quality,I'm running two monitors at 1920x1080 from a 1GB AMD card with no problems.
