Okay so this is my first time buying a pc and ive done a lot of research, i am getting the rig primarily for FFVIX and will continue on hopefully with Fallout: New Vegas and Crysis 2. It will also be used for everyday stuff, itunes, word, internet use etc.
This is what i have come up with... My budget is 750 but can be pushed to 775/780 for a worthwhile upgrade.
PCS MAELSTROM T900 BLACK GAMING CASE (£59)
AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A79XTD EVO: DUAL DDR3, S-ATA II, 2 x PCIe x16, 2 x PCIe x1, 2 x PCI
1GB ATI RADEON™ HD 5770 PCI EXPRESS - DirectX® 11
Memory - 1st Hard Disk
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
1st DVD/BLU-RAY Drive
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply & Case Cooling
CORSAIR 650W PSU (TX650) 80+ ULTRA QUIET (£76)
Network Facilities
This system is overpowered i know but this is too allow for a crossfire upgrade in the future and overclocking which is why i have included the CPU cooler, i hope to be correct in saying this system should be fairly future proof in that i will be able to go from a single 5770 upto dual 5870's if i wanted to and the cpu can be upgraded to 1090T if i felt the need... But should this base system be able to handle my games at medium qualities... i will be playing a 1680 x 1050 native.
I have considered changing the hard drive to a
-1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB CACHE
But i dont like the sound of this intelipower, would the 64MB cache make much difference in comparison to my current 16MB cache?
And one last thing is that i have the possibility of using
-4GB CORSAIR XMS3 DUAL-DDR3 1600MHz (2 x 2GB KIT)
But i dont think my MB is compatible with 1600 speeds... does this make a major difference or is my 1333Mhz fine?
Thankyou for any help.
Network Facilities
