Help with Quiet PC Spec Please
micsim
Hi, I would like a quiet pc, I do some gaming (Total War, Football Manager - nothing too demanding) and editing of +12mp photos in photoshop.
Don't really care whether Intel or AMD, am open to guidance on all aspects. I like the idea/speed of SSD (because the HDD is always the bottleneck) but they are costly. Would like to keep power consumption lowish.
Don't need new screen/speakers & have my own windows 7 disc.
I would like to spend £700 or less, and absolutely cannot go over £1000.
Anyone able to help me on this?
Regards
MS
bg92
Expert
This would be a decent spec.
COOLERMASTER SILEO 500 QUIET MID TOWER CASE
Intel® Core™i5-2400 Quad Core (3.10GHz, 6MB Cache) + HD Graphics
ASUS® P8P67: USB 3.0, SATA 6.0GB/s, CrossFireX™ SUPPORT
1GB AMD RADEON™ HD6870 - 2 DVI,HDMI,2 mDP - DirectX® 11, Eyefinity 4 Capable
Memory - 1st Hard Disk
640GB WD CAVIAR BLACK WD6402AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£78)
Network Facilities
NO OPERATING SYSTEM REQUIRED
NO OFFICE SOFTWARE
Standard Build - Approximately 9 to 13 working days
Quantity
1
Price: £792.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-sandy-bridge-pc/
micsim
Hello bg92 & thanks for your help.
Would the 4GB ram be enough for the photo editing - or is this not an issue?
Regards
Mike
bg92
Expert
You might want to consider gtx570 or gtx470 as photoshop mignht be uing cuda cores, and i5-2500,
The build below is a bit more expensive, upgraded cpu, gtx470 instead of amd6870, and here you get an ssd,
Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) + HD Graphics
ASUS® P8P67 PRO: USB 3.0, SATA 6.0GB/s, CrossFireX™ / SLI SUPPORT
1280MB NVIDIA GEFORCE GTX470 - 2 DVI,mHDMI - DX® 11, 3D (Special Offer!)
80GB Intel® X25-M 2.5" SSD (34nm / upto 250MB/sR | 70MB/sW)***SPECIAL***
2nd Hard Disk
CORSAIR 750W TX SERIES (TX750) 80+ ULTRA QUIET PSU (£89)
Network Facilities
NO OFFICE SOFTWARE
Quantity
1
Price: £990.00 including VAT and delivery.
mikef
I have the Sileo 500 and Vertex SSD. This combination works well - the Sileo's input fan directs air through the disk mount area and with just the SSD and no internal hard disks, the airflow is good despite the Sileo's deliberately restricted air intakes down the sides of the front panel. With a copper cooler you can keep the CPU temps down and fan speeds low. In a typical room you can't hear that this system is on from less than 30cm.
