Help?
Goodjacky
So I was looking on the pc specialist website and I found the review section which has computers at a incredible price saving you up to £150 if you build it with the same components in the custom build section. I just want to know the different between a review pc and a custom build pc. I also want to buy a monitor with my pc but if I chose a review pc I don't have the option to add a monitor what should I do?
Ps nvidia is Releasing their 700 graphics card next month is it worth the wait so 600 series prices can drop so pcs can release more amazing review pc.
Budget is £1000 for pc and £200 for monitor
I was looking at vanquish 670xm mkii
Rakk
The Awesome
There is no difference, it's just to get the discount you need to use the order now button on the reviews page and you cannot change any of the components.
To add a monitor to it, you will probably have to call PCS since any configuration changes will up the price to what it would be without the review discount, I suspect (though I could be wrong mind) they will allow you to add monitors without losing the discount but you will not be able to do it on the website.
