Help??!
Uwais
Basically, Iam planning on purchasing this item As as a gaming pc but i read the specs and it has no gpu:mad:. So.. to fix that i do not mind buying a nvidia 750ti to use as a graphics card but what i need to know is would the 500 watt psu run the graphics card smoothly without crashing or anything?
Help would be appreciated.:sweatdrop::sweatdrop::sweatdrop:
Item: [Link removed]
Rakk
The Awesome
Since PCSpecialist sell custom-built PC's and laptops I'm afraid we are not allowed to comment on PCs from elsewhere (or link to them - so your link has been removed)
But if you would consider ordering from PCSpecialist you could let us know your total budget and what you need (ie. do you need the peripherals as well) and I'm sure someone can spec you up a PCS machine (though you may find the answer is actually that you should really save up some more to get a decent gaming machine)
