Hi, need help choosing the specs for my min pc.
Nuno198
I basicly would like to use it for : work so programs like office 2010 and photoshop .. i will also be using vegas and after affects alot .. gaming wise i would like to play most recent games they dont have to be max settings just at a smooth rate and for alot of internet usage..
What do you guys think .. the cheapest matching that criteria the better..
thx in advance :)
Teaz
Godlike
I would recommend a full desktop pc for those demands, though this is also dependent on how heavy your usage are for those softwares.
What is the budget you're working on?
Nuno198
I will be using programs like microsoft word and powerpoint daily.. photo shop and after affects not so much.. sony vegas i will be using quite alot.
For gaming i want to play recent games on it at a smooth rate..
PCS
Administrator
Staff member
What's your budget and I'll put together a specification for you?
dangro474
Thats very difficult without a roundabout figure >< Will your equire a monitor, keyboard, mouse or any other peripherals?
I would recommend the Intel Gaming Mini PC with 8GB ram, totaling under £800 without peripherals. You may want to up the CPU to a 2600S for Hyperthreading as Vegas will make use of the additional threads.
The 560Ti hits a sweet spot performance wise. Unless you want to experience considerably reduced performance with high detail settings, i would not recommend downgrading to a 550Ti or below.
PCS
Administrator
Staff member
Based on your budget you can easily get a high performance Mini PC, here is a high performance spec with the fastest processor on our configurator, 8GB RAM and an Intel SSD:
Inwin Mini-ITX BM643 Case + 160W PSU
Intel® Core™i7-2600S Quad Core (2.8GHz, 8MB Cache) + HD Graphics
ASUS® P8H61-I: Mini-ITX, LG1155, USB 3.0, SATA 3GBs
8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
1GB NVIDIA GEFORCE GT 430 - DVI,HDMI,VGA
Memory - 1[SUP]st[/SUP] Hard Disk
160GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 165MB/sW)
2[SUP]nd[/SUP] Hard Disk
1TB SATA-II 3-Gb/s HARD DRIVE WITH 32MB CACHE (7,200rpm)
ONBOARD 10 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities
WIRELESS-N (150Mbps) 3dBi HIGH GAIN USB ADAPTER
2 x USB 3.0 PORTS + 4 x USB 2.0 PORTS AS STANDARD
Keyboard & Mouse
LOGITECH® MK250 WIRELESS KEYBOARD & MOUSE COMBO (£21)
Quantity
1
Price: £912.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-top-spec-mini-pc/
Here's a spec that's also very powerful but more budget conscious:
Intel® Core™i5-2400S Quad Core (2.5GHz, 6MB Cache) + HD Graphics
4GB SAMSUNG DUAL-DDR3 1333MHz (2 X 2GB)
120GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 130MB/sW)
500GB SERIAL ATA II 2.5" HARD DRIVE WITH 8MB CACHE (5,400rpm)
Network Facilities
Keyboard & Mouse
Quantity
1
Price: £699.00 including VAT and delivery.
