Just a quick question (wasn't sure where to ask this on the forum) - Does anyone know if there's any 12-cell (which is 7800 mAH I think) batteries available that are compatible with the Optimus V 15.6"? They're 14.8V, and the 8-cell supplied by default are 76.96Wh (model W370BAT-8) li-ion. I'd very much like to add something with a bit more beef but finding one that's compatible is proving to be tricky (even looking through OEM catalogues I'm struggling) - dimensions, prong position, and voltage are the keys but something with higher mAH rating would be great. To clarify, I don't simply want an additional battery that I'll have to swap out, I want a single higher capacity battery. It already lasts 4-6 hours on moderate usage between charges but pushing this up to 3-4 hours of intense gaming or 8-9 hours of moderate usage would be great (I've got it setup as I like and I'm minimizing power usage where ever I can).
Alternatively, can anyone recommend a good quality high-capacity mobile battery pack that I can simply plug in to this Optimus V power port to extend the runtime? I've not got the charger in front of me so I'm not sure what it's output voltage or amperage is (I'll check this later but any recommendations in the mean time are welcome). I've seen a few on Amazon (some as high as 26000 mAH) but I'm not sure if they're rated correctly for the Optimus V or not (or whether they're good quality) or whether they're just aimed at mobile phones and tablets (i.e. with 2A or 1A USB outputs).
EDIT: Charger output is 19.5V at 6.15A (120W).
