Hi!
You guys proved to be really helpful last time I ran into issues, so I'm coming back!
I have a rather complicated question: has anyone here used Hot CPU Tester Pro? Because for me, the program is showing following errors on a customer's PC:
What's funny is, 5 hours later after the test is finished, the minidump files are gone and all I get is "Test finished successfully" messages. No other error messages since these ones. What's the deal? Is it a some kind of a bug? I'm wondering if these aren't fake errors since the program seems rather outdated (2007 or something).
The build is a Gigabyte B360 HD3 with an Intel i5-9400F.
Code:
000108| 9999 00001dcc Jun, 09 - 21:59:32 | Error:CPU 2: MFC QuickSort: Checksums do not match; a[19523] = 1608, a[19523] = 1607
000109| 9999 000020ec Jun, 09 - 21:59:32 | Error:CPU 0: MFC QuickSort: Checksums do not match; a[23619] = 1932, a[23619] = 1933
000110| 0000 00001dcc Jun, 09 - 21:59:33 | Minidump file saved at C:\Program Files (x86)\Hot CPU Tester Pro 4 LE\\HCTJun09-215932.dmp
000111| 0000 000020ec Jun, 09 - 21:59:33 | Minidump file saved at C:\Program Files (x86)\Hot CPU Tester Pro 4 LE\\HCTJun09-215933.dmp
000112| 9999 00001ba0 Jun, 09 - 22:07:24 | Error:CPU 3: MFC QuickSort: Checksums do not match; a[16644] = 1368, a[16644] = 1367
000113| 0000 00001ba0 Jun, 09 - 22:07:24 | Minidump file saved at C:\Program Files (x86)\Hot CPU Tester Pro 4 LE\\HCTJun09-220724.dmp
