topcat5665
I'm talking about those black ones that wrap around the wires to keep them tidy. I want to upgrade my computer, but I can't because they are all tied down... Any idea how to remove them?
Thanks.
Thanks.
Yeah just get a small, thin pair of scissors and slip them underneath and cut. Obviously be careful not to cut through anything else!
I usually use a Stanley blade for the ones that are really tight, and just put a few slashes in it then they usually just break open the rest of the way. What ever you use you will obviously need to be careful.
