Hi guys
I have a few questions about this system build
Does (ASUS® ROG STRIX Z370-E GAMING) have wifi if not i will get Gigabyte Z370 AORUS Ultra Gaming and wifi pci card
If i have Noctua i have two choices COOLERMASTER MASTERBOX 5t or FRACTAL DEFINE S BLACK GAMING CASE what would you chose
Are aios worth having in general or is it better to stick with air cooling
Another option i see is going for FRACTAL FOCUS G and 240mm aio
either CoolerMaster MasterLiquid Lite 240 is it good enough to cool overclocked pc, what are the noise levels
or Corsair H100i V2 as far as i know it is loud would upgrading to silent fans help a lot
I do not want to go over 2000£
FRACTAL DEFINE S BLACK GAMING CASE (Window)
Overclocked CPU
Overclocked Intel® Core™ i7-8700K Six Core (3.7GHz @ up to 4.8GHz)
ASUS® ROG STRIX Z370-E GAMING: ATX, LGA1151, USB 3.0, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE RGB DDR4 3000MHz (2 x 8GB)
11GB NVIDIA GEFORCE GTX 1080 Ti - HDMI, 3x DP GeForce - GTX VR Ready!
Get Destiny 2 with select GTX 10 Series GPUs! ** Limited Codes Available **
2nd Hard Disk
1TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
M.2 SSD Drive
512GB WD Black™ M.2 NVMe PCIe SSD (up to 2050MB/s R | 800MB/s W)
Noctua NH-U14S Ultra Quiet Performance CPU Cooler
EK-TIM ECTOTHERM THERMAL COMPOUND
Price £2,002.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-overclocked/SETGVuzjah/
Overclocked CPU
2nd Hard Disk
M.2 SSD Drive
