Hallo
My in build microphone stopped working and it currently not plugged in so i cant enable it . When i go to set up a microphone it says No audio input device found . The microphone is on conexant SmartAudio HD and when i go to device manager there is a yellow error over realtek high definition audio .There are currently 3 sound drivers AMD high definition audio device(Monitor) , conexant smart audio HD(current driver) and the realtek which i just installed .
i tried uninstalling and installing the driver with no luck.
Toshiba L755D series
Thanks for any help
Thanks for any help
