Grumpywurzel
Ok, Ok, I know I'm probably in for a kicking here, but does anyone know why I never see any of my cores ever go above 4.7 GHz? Checked with CPUID, HWMonitor and even Task Manager and they all show ~4.6-4.7?
I've looked into the Bios and Control Center and it looks like it's setup to run single core boost to 4.9? Core 2/3 boost to 4.8 and all core to 4.7 (which i see all the time) Power management is on max settings/power plan
I know we are literally talking a tiny delta here, but the machine has been like this since new. Will it be down to a crappy bit of silicon? No issues with temps either, sat at 40 ish degrees. Not even remotely thinking of trying to get it returned as I know there is nothing PCS can do, just wondered if there was a setting that hasnt been enabled or something
Cheers
Garry
Cheers
Garry
