Is there a big difference between choosing standard thermal paste over Arctic MX-4?
sean16
I was wondering if I should go for either the standard thermal paste or Arctic MX-4 option for my new build.
I've heard Arctic MX-4 is one of the best thermal pastes out there and I used it myself to replace the old thermal paste on my current PC.
Wouldn't the MX-4 last longer and be more effective?
Thanks.
Bigfoot
Grand Master
Thanks.
It depends on your spec. If you have a Corsair AIO cooler in your build, you don’t need the Arctic paste as the cooler comes with high quality paste pre-applied.
Thanks.
Depends which cooler you buy, Noctua, Corsair and CoolerMaster cooling units come pre-applied with good quality paste. So you can actually create more hassle by adding the MX-4 because they’ll have to remove the original paste to add the new one and if you get a bad paste job you’re worse off and an extra tenner out of pocket.
sean16
Going for a CoolerMaster, so all good, yah?
sck451
Not sure about the others, but FWIW my Noctua cooler didn't come with paste pre-applied: it did come with paste in the box. I don't know whether this would be included in an OEM package.
That’s interesting, I’m sure I saw a vid with a Noctua fan cooler where they just peeled off some plastic to reveal paste and squidged it straight onto the CPU. I’m going to have to see if I can hunt it down... 🤔
sck451
All the videos on Noctua's website (that I've found) show the paste being added as part of the installation process. Here's what I got in my box (with my silly NH-D15S).
