Hi - here's the spec I've chosen (my budget is about 1000 GP). I mainly wanted to check whether this will work with the Quadro FX1800 graphics card. If anyone could let me know either way I'd be very grateful. I'll be doing mainly simple animation, nothing hugely complicated. Thanks.
COOLERMASTER SILEO 500 QUIET MID TOWER CASE
Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) + HD Graphics
ASUS® P8P67 WS REVOLUTION: Unmatched Graphics Performance
8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
Memory - 1st Hard Disk
1st DVD/BLU-RAY Drive
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan (£29)
INTEL SOCKET LGA1155/1156 STANDARD CPU COOLER
Network Facilities
2 x ONBOARD 10/100/1000 GIGABIT LAN PORTS
8 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (£109)
Network Facilities
