Just had a power cut..What do I do and look out for?
bigmaraippo
Hey all,
Hope you're well.
So just had a power cut, the moment it happened I rushed to the power supply to turn the switch off.
My PC is plugged into a power surge extension cable. 3090 is also undervolted and the PC is on Power Saving mode.
Are there any tests or things to look out for?
Here is my build;
CORSAIR OBSIDIAN SERIES™ 500D SE CASE
24GB ASUS ROG STRIX GEFORCE RTX 3090 - HDMI, DP
2 PORT (2 x TYPE A) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Standard Build - Approximately 13 to 16 working days
Hey all,
Hope you're well.
Here is my build;
With a surge protector, you don't need to worry, it blocks any surges that occur during a power outage.
There's nothing you need to do, don't turn off the surge protector though next time, just let it do it's thing.
bigmaraippo
Hey Spyder,
Sorry I meant I turned off the power supply of the PC, the power surge extension cable was not touched!
