Lafite II questions for potential buyer
andva
Hi I have been thinking of buying Lafite II for some time. There are, however, some question to which I would be happy to get answers. Either from the ppl from PCSpecialist or some owners of the said NTB.
1) Does PCSpecialist plan to make versions with i5-6300U CPUs? If yes when.
2) What is the brand/name of used MTB.
3) PPL complain about the fan noise. Do you think replacing the fan with a quieter one would help?
4) Does the NTB use DDR3 or DDR3L and is the RAM soldered?
5) DDR4 RAMS now cost the same as DDR3 and Intel says these are preferred for Skylake. Will PCSpeciliast offer this option?
6) The supplied battery takes a long time to charge. Has anybody tried a different charger or changing the battery altogether?
Thx
Laron
1. Don't count on it, 6200U/6500U will be milked forever.
3. It's not that the fan itself is loud, it's the poor (automatic) fan control which annoys people, and you can't change the settings.
5. Not likely on this current Lafité II, but obviously DDR4 will start to appear on other future models.
