Laptop battery drains when the charger plugged in and is in gaming mode
Mr. T
Hello everyone,
I have an IONICO 15 II laptop that I bought recently, it has an I7 11800H, 32GB of RAM and an RTX 3070. I noticed that when I run games or render videos and the laptop is in gaming mode the battery starts draining. At first I was suspecting that the laptop charger (230 watt) couldn't provide enough juice. I tried to play with Control Center's performance settings but it just cripples the performance, the default config is:
LP1: 45 watt
LP2: 45 watt
LP4: 110 watt
GPU: 125 watt + 15 for turbo boost, I didn't have the option to change that but after digging inside the Windows registry editor I found the key to enable it, but even then it game only the option between 125 and 126 watt.
and because I needed a second charger anyway I order another one also 230 watt, and it gave the same issue. Then I order a small device from amazon to measure how much power the laptop is drawing and it gave this:
In office mode, running a game will peak at around 100 watt
In Game mode it peaks at around 180.
when I set LP1/LP2/LP4 to 45 watt in gaming mode the peak was around 150/160.
So there is still room for the charger to give more power.
Then I started searching on the Internet and found similar issues reported on laptops from big brands, they do it because there laptop chargers can't provide enough power so they came up with a technology called Hybrid Power to use energy from both the battery and the charger at the same time. my question is how to disable this on PCS laptops because I see that it shouldn't be needed with a 230 charger? or is that intentional to make batteries die quickly so that they can sell you new ones?
Hello everyone,
LP1: 45 watt
LP2: 45 watt
LP4: 110 watt
Hiya, is this a PCSpecialist laptop? Could you post your full specs from the order page?
Mr. T
Yes, a PC Specialist laptop, here are the specs:
Chassis & Display
Ionico Series: 15.6" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440)
Intel® Core™ i7 Eight Core Processor 11800H (2.3GHz, 4.6GHz Turbo)
32GB Corsair 3200MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
2TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 3000 MB/W)
AC Adaptor
1 x 230W AC Adaptor
1 x 1 Metre European Power Cable (Kettle Lead)
Battery
Ionico Series Integrated 62WH Lithium Ion Battery
1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS
Keyboard Language
IONICO SERIES RGB BACKLIT UK KEYBOARD
NO OPERATING SYSTEM REQUIRED
Germany/Deutschland - German Language
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
2 DAY DELIVERY TO GERMANY
Promotional Item
Get Guardians of the Galaxy with select GeForce RTX™ 30 Series GPUs
Welcome Book
PCSpecialist Welcome Book - Germany
I don't think it's something that can be disabled at all, its inherent in the power circuitry.
The PL power levels are purely for the GPU, doesn't account for the rest of the system
