Laptop For CAD etc
Snewlands
Hi folks,
I'm basically needing a laptop for univeristy, which will run drawing and rendering programmes (CAD, Revit, 3DS Max etc) without any real issue...
Now I'm not looking to go overboard on spending, however do require an SSD, as from what I'm aware they're a lot more quick and sturdy!
My budget would be around £750, as I look to purchase an external hard drive worth around £50 for storing my actual files on.
I have came up with a model I hope would do the job, however it's maybe completely out of sorts...
Chassis & Display
Genesis IV: 15.6" Glossy Full HD LED 16:9 Widescreen (1920x1080) (£35)
Intel® Core™i7 Quad Core Mobile Processor i7-3610QM (2.30GHz) 6MB
NVIDIA® GeForce® GT 630M - 1GB DDR3 Video RAM - DirectX® 11
Memory - Hard Disk
120GB INTEL® 330 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
DVD/BLU-RAY Drive
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® N130 802.11N (150Mbps) + BLUETOOTH
2 x USB 3.0 PORTS + 1 x USB 2.0 PORT AS STANDARD
Battery
Genesis Series 6 Cell Lithium Ion Battery (48.84WH)
Power Lead & Adaptor
1 x UK Power Lead & 65W AC Adaptor
Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
NO OFFICE SOFTWARE
Keyboard Language
INTEGRATED UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
Webcam
INTEGRATED 1.3 MEGAPIXEL WEBCAM
Insurance
Snewlands
Also, how portable are they? I need to take this too and from uni, and have been informed they are fairly bulky...
How are they in regards heat as well? My last few laptops have got hot due to the rendering tasks etc, and in turn have damaged my hard drive...
Angelmaker30
with the software you want to use I would possibly go for more RAM as it will help with a heavy workload. I don't know exactly how heavy but I understand it packs a pretty decent weight, though being a 15" screen will help a bit.
Snewlands
Thanks for the reply Angel!
Should the 8GB not be enough for RAM?
Also just checked the weight, and it appears to be 2.3kg.
