Hi there
I wonder if you can help. I would like to buy a new laptop from you guys to be used for music production. As you may be aware there are quite a number of factors to consider when choosing a laptop for this usage due to the unusually high demands audio streaming and processing tends to put on a system..
The laptop I have spec'd up looks like this
15.6" GenesisII
Intel® Core™i5 Mobile Processor i5-540M (2.53GHz) 3MB Cache (Special Offer)
4GB SAMSUNG 1066MHz SODIMM DDR3 MEMORY (2 x 2GB)
Mobile Intel® 5 Series Integrated Graphics
500GB WD SCORPIO BLACK WD5000BEKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
ONBOARD GIGABIT LAN & WIRELESS 802.11N CARD (AS STANDARD)USB Options
Genuine Windows 7 Home Premium 32 Bit - inc DVD & Licence
I would be using an external USB audio interface and using software such as Cubase and Ableton Live. The prices PC specialist offer seem to be excellent value so im keen to order.
My worries are that if the laptop turns out to be unsuitable for the job, will I be able to return it? As its being custom built I would imagine this could be a problem, especially if the laptop does technically 'work', if you see what i mean, but just isnt up to scratch for music work. Could you clarify the situation for me please?
Also, an issue regarding something called DPC latency. This is a very important consideration for audio laptops but this is something that I am unable to check before ordering. The latency of the system needs to be below a certain level for it to operate effectively. There is a free utility that can measure the DPC latency of a system -
www.thesycon.de/eng/latency_check.shtml
I wondered if you would be able to reassure me of the performance of my/a closely spec'd system by running this utility and showing the results? It would put my mind at rest a lot in terms of putting an order in.
Basically, if all looks good then I would be glad to order from you guys within the next week. Ive done the rounds on the internet and put the PC specialist name about quite a lot in my quest for info as well! Any advice would be gratefully received!
Thanks
Ewan
15.6" GenesisII
Thanks
Ewan
