No, this isn't correct.Sorry OP I am derailing this thread. MSHybrid and Optimus are exactly the same thing, the MUX is the switch which is used to switch between MSHybrid/Optimus and the dGPU.
Optimus was the first iteration of GPU switching, this was just a
MSHybrid came later but is essentially the same
Then recently came MUX. Mux actually reroutes the graphics output directly to the nvidia card by switching the actual circuitry it's passing through. This requires dedicate hardware and is very new. It completely bypasses the iGPU and disables it.
On a previous generation, this is why you could never disable the iGPU even if you'd enabled dedicated graphics, if you did the screen just wouldn't work, because even if you're running off the dGPU, it's going via the iGPU firstly. So iGPU was always enabled.
What is a MUX Switch for Gaming Laptops? - Jarrod's Tech
A MUX switch lets you disable the integrated graphics in your gaming laptop, giving you a performance increase in games at the expense of worse battery life. To understand what a MUX switch does, you need to first understand how Optimus works. October 2023 update: MUX switch matters less with...
